They wont let me on the track
RE: They wont let me on the track
the rule for houston raceway park is pretty much do whatever you want if you run an 11.99 or faster and you have a vert you need a rollbar. but they let that slide pretty much all the time cause we got dd street cars that run 10's all day with some power adder. and like 50-65% of those cars are faster than 12.5
each track is different in their enforcement of the rules...if they won't let you run then go get a roll bar you have no choice or not run[:@].....our track is 13.99 on verts
13.99 for vert's here.
kinda lame, im also about 90% sure you have to wear a helmet no matter how fast you are too!
im racing on this coming wedsday, so we shall see, i can let you guys know what they tell me.
bandimere speedway, colorado
NO kidding right! If you have a rock stock GT converitble, you can't run it at the track! I know Shelby convertible owners would probably be really hesitant to put a rollbar in their cars, so how many of them will never get to make a pass! That sucks. I thought 12.99 was the number you couldnt exceed in a vert without a rollbar.
ORIGINAL: JerseyRR
They F-in wouldnt let me run at all!
Was looking at the rules for our track,
**Any Car Using Slicks Needs a Drive Shaft Loop**
14:00 & Up
Catch can
Seat Bealts
Neutral Saftey Switch
13.99
Helmet Snell 90 or Higher
11.50 - 13.49
Roll Bar or Roll Cage For Convertibles
10.00 - 11.49
Aftermarket Rear Axles (10.99)
Harmonic Balancer (10.99)
Transmission Shield (10.99)
Drive Shaft Loop
Current Seat Belts (5 Point SFI)
Flywheel Shield
Fire Jacket
Arm Restraints (Open Cars)
Roll Cage/Roll Bar
Window Net for Roll Cage
14:00 & Up
Catch can
Seat Bealts
13.99
11.50 - 13.49
10.00 - 11.49
Drive Shaft Loop
Flywheel Shield
Fire Jacket
Roll Cage/Roll Bar
