6al-2
I thought the -2 had a 2 step built in?
*edit* Yup!
*edit* Yup!
MSD is excited to announce the next generation of 6-Series ignition controlsthe 6AL-2! These all-new ignition controls combine a new housing, new digital controls, and more power in a sleek package. You still receive the 20 degree duration of multiple sparks, combined with higher output to ensure complete combustion. There is a 2-Step rev control built into the housing, but there are no rpm modules! Adjustments are made via four rotary dials for 100 rpm increment control! The all-new capacitive discharge ignition will easily connect to nearly any 12 V negative ground distributor system, even Hall-effect pickups. They offer higher output, with up to 135mJ and 535 V, and accept points and mag pickup triggers.
This new unit offers more output than the standard 6AL , and more digitalized.
The only thing I like about the boxes is that, they help traction with the 2 step, and improve throttle response.
As far as the Rev Limiter in RPM, I dont know if the ECM will still regulatemax RPMwith this box or not.
In any case, if you are not modded with HCI etc, dont expect much.
