lets talk low hp #'s
mainly, why my car only maid 313 hp, it surprised the hell outta me, even with my aode and on a mustang dyno i was hoping for atleast 350. So why's it so low? any suggestions, or is this normal.
quick list of the setup
347
canfield heads
holley intake
custom cam
bbk equals, or h, flow's
all air/fuel upgrades required
347
canfield heads
holley intake
custom cam
What was the A/F at? what was the timing at? What was the weather like? where are you at. can you tune the car in any way or are just relying on the stock EEC? what kind of compression does it have?
wow thats a lot of questions, only specs on the cam i know of are .592/.600 lift, 114lsa.
not sure exactly what the a/f was, i told the tuner to set it just a tad rich for safety, weather was probly around 80 or so, mild humidity, in michigan. car was dyno tuned before the pull, compression should be around 10.5:1.
man it could be one thing or multiple things working against eachother
rockers too tight or loose?
timing ?
what is the compression of the motor? just curious?
how is the aode ?
a/f ratio?
converter ?
man its just hard to say
timing ?
how is the aode ?
a/f ratio?
converter ?
rockers weren't loose, but i guess they may have been to tight, tuner also set the timing so i'm not sure what that was at. aode is fine, fairly fresh rebuild with shift kit, 2800 stall edge converter, aluminum shaft.
I'm not dissapointed in teh car at all, in the 30 miles i drove it it felt very strong when i would just tap the gas and you could tell it wanted to go, and man did it sound good
I guess i was just expecting more power out of it.
^^^^^^why not my friends tired 306 with an h/c/i made it to a best of 12.94@105 with 258 rwhp, 313 is plenty to do that and your low dyno numbers lie with the worthless mustang dyno IMO, all the mustang dyno does is depress people, worry about what matters and get your car fixed and run an ET
