Question about the PCV
Old Aug 17, 2008 | 03:19 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default Question about the PCV
Is the PCV hose from the valve cover to the throttle body really that important? at this point im a little worried about losing oil through there due to not having a baffle in the VC, is there any way i can prevent this, can i just block off the lines, longer hose ( i saw a guy with a 93 cobra that had like a 3 foot PCV hose over looped around his MAF and back to the throttle body, he said it was something to do with this problem
Old Aug 17, 2008 | 05:03 PM
LX 90's Avatar
LX 90
I would deffinently keep it. It keeps the engine from having fuel and contamination in your oil. with it blocked off could cause dirty oil sludge. It vhentilates the cranckcase.
Old Aug 17, 2008 | 05:20 PM
FuzzyDiceRule
how so, there is already a fatty one in the back anyway, i dont understand why i need one in only ONE valve cover when theres already the big one in back
Old Aug 17, 2008 | 06:36 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Just cap it off and run a breather in the valve cover.
Old Aug 17, 2008 | 07:39 PM
LX 90's Avatar
LX 90
Thumbs up
^^^^^^^ This will also work well....
Old Aug 18, 2008 | 02:55 AM
FuzzyDiceRule
rry? sweet
any idea of what i can cap the ends off with?
Old Aug 18, 2008 | 03:12 AM
primetime5.0's Avatar
primetime5.0
your not supposed to run an open breather and a pcv.. Im running the hose from the vc to the tb without a baffle.. I have no issues
Old Aug 18, 2008 | 03:17 AM
primetime5.0
"dont install an open breather to any of the valve covers if the PCV valve setup is kept. This will cause an Unmetered Air (vacuum leak) condition due to air from the atmosphere been sucked into the crankcase. Fresh air intake to the crankcase (specially on MA EFI systems) have to be sourced from the air volume metered/measured by the MAF (reason for the OEM breather hose from the oil tube to the TB on the RH valve cover). Otherwise, a lean condition + idle control problems are likely to occur. If you want to install breathers, the PCV valve must be removed so an unmetered air condition is avoided."
Old Aug 18, 2008 | 03:23 AM
FuzzyDiceRule
okay, you said you were unbaffled, do you burn oil, or are you good?
i guess ill figure something out if i start loosing a bunch of oil
Old Aug 18, 2008 | 03:49 AM
primetime5.0
doesnt burn any oil, been working fine for a while now
