resetting computer
Old Aug 26, 2008 | 11:09 PM
jeffp2152's Avatar
jeffp2152
Default resetting computer
i redid the timing on my car and i was told that i need to reset the computer. how do i go about doing this?
Old Aug 26, 2008 | 11:36 PM
ewgoetz's Avatar
ewgoetz
Disconnect the battery and wait 15 to 30 min than reconnect.....only thing you need to do if you redid the timing is before you set the timing you pull out the timing spout connector, set the timing you want, than reconnect the timing spout. than you should be good to go. Heard you can unconnect and connect the timing spout while the car is running but personaly I like to disconnect the spout than start the car and set desired timing than turn off the car and reconnect the timing spout.
Old Aug 28, 2008 | 02:54 PM
jeffp2152's Avatar
jeffp2152
so do i put the pill/spout back in before or after i reset the computer??
Old Aug 28, 2008 | 03:24 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you don't need to reset the ecm when soley adjusting timing
piotrek53
Oct 13, 2015 06:54 PM
ChampInSD
Oct 2, 2015 04:55 AM
mltdwn12
Sep 23, 2015 08:54 AM
yourmom6990
Sep 14, 2015 10:52 PM
TfcCDR
Sep 14, 2015 12:08 PM
