how much psi
boost is only a measurement of restriction so you can run as much as you want.... But I ran 14psi on stock stuff for a year. Customer of mine is running the same 14psi on his stock stuff also other then the E cam and gt40p heads and a ported cobra intake it does have forged pistons but the rest of the bottom end is all stock it runs pretty good 7.00 in the 1/8 mile that comes out to around 11.00 in the 1/4. all without a tune also.
with all the stock stuff you can run 14psi but you'll need to upgrade fuel system and have a tune and it most likely will not see 14psi as the stock heads and intake will be the flow restiriction that'll impeed greater boost levels, most likely you'll see around 11 to 12 with the 14 lbs pulley
No, the more the restriction the more the boost think about blowing through a straw then blow through a 2in pvc tube. what gives more back pressure. the only up grade to Brian's car as far as fuel is the big injectors and the 2nd inline pump and the good mass air . No tune other then what I can do by hand it has the 14psi pulley but yes by the time it gets through the intercooler it is 11 so I lied a little. we will be putting the 17psi. pulley on before the end of the year. then it will be 14psi.
with a totally stock setup i wouldnt go over 10 psi but with a good upgraded fuel pump and injectors 12-14-16psi? how lucky do u wanna be as with that much psi i wouldnt be beating the snot out of it all the time.
I know you want less restriction. No kidding guys. What I said was that the more the restriction the more boost you will see and that boost is only a measurement of restriction No where did I say that you was gone to make more power or less power did I ? Back to blowing through the straw (without water this time LOL) blowing through the straw makes you more red in the face then blowing through a 2in pvc pipe why because there is more restriction.now if we could put a gauge on your face there would be more press/boost. better flowing parts will give less boost but move more air so in that you will move more air with less boost press. and "should" make more power
aren't you suppose to be at work!!!^^^^^^^^labor day implies work!!!!lol!!!! So I WENT TO WATCH RACING TODAY, what a waste of money!!! more so gas money, not to many cars there meaning street cars, and more so them stupid ugly rail cars and loud 8-9 sec rides, stuff you'll never see on the street!!!.oh and as far as the straw thing, I agree , i'D RATHER make more power with less boost initially cause in the end there is more room for potential, also a bigger straw makes it easier to suck up those SHEETZ milkshakes instead of the punny ones lately they have been sitting out there!!! takes me twice as long now to finish the shake and no where near as enjoyable now that I spend more effort trying to suck up the shake!!!!!
