big block fox overheating???
Old Aug 31, 2008 | 06:36 PM
monkeyboy's Avatar
monkeyboy
Default big block fox overheating???
Me and my dads working on a foxbody and we dropped a 460 in it. We put in a bigger radiator, and have a big flex lite fan on it. Dad wants to make it to where he can drive it on the weekends. But on all our test runs out in the country it always gets hot. We took the thermostat out and it didn't help. There's water flowing thru the radiator when it's running. So what else could cause it? it goes up to 220-230deg. I know the motor has been rebuilt at one time. But I have no idea what they did to it. This cars.. kind of a... son teaching father... on a cheap budget thing. So needless to say.. the stangs rough and it explains using used stuff. I'm not getting any oil in the radiator. Or water in the oil. Neither am I losing oil or water. So I wouldn't think it would be a head gasket. I know when the motor was in the truck before it didn't run hot. The radiator was a used 2. So maybe that's whats wrong. But I flushed it and it seemed to flow pretty good.
Old Aug 31, 2008 | 06:40 PM
kingcobracustoms's Avatar
kingcobracustoms
same size radiator that was in the truck?
Old Aug 31, 2008 | 06:58 PM
w8less's Avatar
w8less
burp the system it could have air in it
Old Aug 31, 2008 | 07:05 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
make sure the radiator you are using is for the cooling requirements that a 460 demands
Old Aug 31, 2008 | 07:44 PM
monkeyboy's Avatar
monkeyboy
Yeah... the radiator's the looks same thickness as what was in the truck. I don't know what it was out of. I just kinda measured the biggest I could fit and called the junkyard. And I told them I wanted 3 or 4 core. Because it was going in front of a big block.
Old Aug 31, 2008 | 08:13 PM
ctgreddy's Avatar
ctgreddy
i know you said ur on a budget but i'm sure a fluidyne or becool would really help with the heat.
Old Aug 31, 2008 | 09:07 PM
mjr46's Avatar
mjr46
looks can be decieving, inside core diameter is what'll matter for adequate flow
GimpyHSHS
19
Dec 19, 2023 01:12 PM
BOB ROME
Jul 26, 2023 01:54 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
mustangheaven
Sep 29, 2015 11:00 AM
