Need help finding proper rack and pinion
I need to replace an inner tie rod end, so I figure may as well replace the entire rack. I'm looking for one but there are different "types".
Would this one fit a stock 91 GT?
http://www.latemodelrestoration.com/...0%201&comp=LRS
What's the difference between a "Ford Gear" With 2 Piece Mounting Bushings and a 1 Piece Mounting Bushing and a TRW Gear?
Do I want to get one with 3.0 turns, 2.5 turns or 2.25 turns?
Also there's some without performance suspension, some with agr performance.
What's a firm valving? and what's the deal with the ratios? 15:1, 20:1 .... this is way too many choices for a novice. Consider the novice man!
turn your wheel; lock to lock now and count what you got, that'll answer that question and IMO the LMR kit is a little pricey since I bought a reman one at Napa that cost 70 bucks and came with everything but the outer tie rods and sway bar links, if yours are fine just transfer outer over
yourmom6990
09-14-2015 10:52 PM
