Intermittant exhust backfire all RPMs Help!!!
Old Sep 2, 2008 | 01:00 PM
bhorse's Avatar
bhorse
Unhappy Intermittant exhust backfire all RPMs Help!!!
It might disappear for a week. Then it's back. Backfire through the exhaust. It's not constant; it comes and goes at all RPMs. At a steady speed I can feel the car switch from running ok to running great. Fuel pressure holds at 40 no fluctuation. 1989 5.0 mostly stock.
Has anyone had this particular problem? What did you do to fix it?
Old Sep 2, 2008 | 10:51 PM
mustangsneverdie's Avatar
mustangsneverdie
it sounds like to me that your runnin rich
Old Sep 3, 2008 | 01:20 AM
FuzzyDiceRule's Avatar
FuzzyDiceRule
check the timing, sounds like your TFI module/dizzy might be bad
Old Sep 5, 2008 | 02:01 PM
bhorse's Avatar
bhorse
The ghost is still in the machine but here's what I've done so far.
Went ahead with the distributer and TFI and the indicial test seemed to change the situation. But at 4000 RPM the thing acted like I had a rev limiter on it. At that point I hooked up a new coil and bingo, revved it up to 5000 no problem. YEE HAW! Or so I thought. Heading home two blocks away and POP POP. Also cutting out at around 4000 again.
This morning I found the PVC out of the grommet so I think surely I'm onto something now. Put it back in, test drive one POP and I'm still at square one. Thankfully I have most of these parts sitting here.
What would be the result of a bad PVC?
Would a malfunctioning injector do this?
Any help is much appreciated.
Old Sep 5, 2008 | 09:30 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
it's possible^^^^^^^^^^ also check the plugs and make sure they are not fouled
Old Sep 5, 2008 | 09:32 PM
mjr46's Avatar
mjr46
may have a bad stator in the dizzy
CS2007
Jun 25, 2019 09:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
svfetter
Oct 5, 2015 11:39 AM
SteelerNation82
Sep 16, 2015 07:11 AM
zanemoseley
Sep 6, 2015 12:58 PM
