whats the power diffrence??
whats the power diffrence in a 93 lx 5.0 when switching from a stock cam to a f cam? just done the swap on a buddies car and wanted to get a idea of the diffrence, thanks.
agreed, you are probably right were you started right now. To utilize the cam you will need a better flowing set of heads, intake, injectors and everything else that is assosiated with h/c/i
Granted the car is probably going to sound meaner then it did, but your gona be in the exact same place. also did you check the valve clearence when you put the cam in?
car with stock e5's and stock cam ran 13.70's to 13.80's at 97-98 mph, with e7's ported and f-cam it still does that, the heads are what is killing it, it needs heads but no money right now for them
donor car was an 85 gt my 92 is a 4cyl conversion
