Question About Cutting Springs.
Old Sep 17, 2008 | 08:42 PM
Sidewayz6.0's Avatar
Sidewayz6.0
I used a bench grinder and just ground through them. Theres nothing wrong with cutting them, in fact the Moroso trick springs I have say "Cut to desired ride height" on the installation directions. Just don't heat them up with a torch. Thats what gives you the ricer bounce and makes them unsafe.
I think I took a coil and a 1/4 out and the thing sits perfectly.
Old Sep 17, 2008 | 08:43 PM
Sidewayz6.0
Hmmm...I think I'm going to use that picture in my sig. It actually looks badass there.
Old Sep 17, 2008 | 08:47 PM
Explosive's Avatar
Explosive
Alright, now to figure out how much to cut.
Old Sep 17, 2008 | 08:52 PM
Sidewayz6.0
Lob a coil out, and see how she sits. If it's too high, pull them out and take a half off. (Yeah, I know that sucks, I did mine twice.)
I swear the guy that invented the spring compressor had a death wish.
Old Sep 17, 2008 | 11:02 PM
Shelty's Avatar
Shelty
http://www.parts123.com/parts123/yb....Z5Z5Z50000016d
cheapest set of springs you can find new
Old Sep 18, 2008 | 12:19 AM
crusin92red5.0's Avatar
crusin92red5.0
cut an one coil then re-install to see the height, then do incriments of 1/4 coil. i cut mine until i had the money for lower springs.
Old Sep 18, 2008 | 02:17 PM
Explosive's Avatar
Explosive
Sidewayz6.0 : We couldn't for the life of us get our springs in, then I told my dad, lets put wood across the engine bay and put all the cinder blocks can we get on it. We had so much freakin weight on there. That and a couple other little things we finally got them on, I'm afraid if we take them off we won't get them back on. Being shorter should help.
Old Sep 18, 2008 | 04:36 PM
crusin92red5.0
did you use a large pry bar to hold the spring in the perches while you had the jack under the tip of the control arm?
Old Sep 18, 2008 | 04:41 PM
Explosive's Avatar
Explosive
None of that worked because the whole car would lift. So we did the bricks then put a ratchet strap on it and compressed it together and it worked.
Old Sep 18, 2008 | 05:01 PM
crusin92red5.0
thats wierd, i never had that happen, is the engine out? was the car jack up high enough?nice way of getting around the obstacle though...
