Question About Cutting Springs.
Ok, as most of you know, our car sits to high in the front. Sure, you don't have to worry about hitting parking blocks but thats about it.
So, I know a lot of people just cut the springs down, how would I go about doing this ? What should I cut them with ? How much should they be cut ect ?
~Thanks.
~Thanks.
i did mine that way for now till i get some more $$ and buy real springs..but for mine i cut 1 and 1/8 coil off each front...to cut it i used a band saw that we have and with a brand new blade cut threw in about 10 seconds or there about..used some cutting oil and right after it cut threw i touched it and wasnt even hot...
cutting springs is a dangerous thing to do. greatly reduces the overall stability of the spring.
if you want a lower ride, cheap, go junkyard shopping and find a 4cyl, and take the front springs from it.
they flex more, so the ride will sit lower, and the car will jump higher when launching, causing better weight distribution, therefore stickier launches.
