331 in a 4 banger frame question
Old Sep 18, 2008 | 03:13 AM
Sidewayz6.0's Avatar
Sidewayz6.0
I guess...Hmmm. I don't see why you'd have to. I know when you run a MAF computer, and a 4 banger dash harness, none of the gauges will work.
It's been a while since I've been stumped with a foxbody question...But here I am. I don't know the answer to this, I've never put a carb'd motor in a 4 cyl. shell.
Old Sep 18, 2008 | 12:37 PM
jtmustang's Avatar
jtmustang
^^got ya.............haha.
Old Sep 18, 2008 | 02:13 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Originally Posted by Shelty
in actuallity, the 2.3 K member is a few pounds lighter than the 5.0 k member.... dont ask me why, but I found that out in a MMFF mag...
don't know why they'd say it is cause it's the exact same one as a 5.0 all I had to do was use 5.0 motor mounts, it couldn't tell any diff between my 5.0 k-member an the 4 cyl one.
Old Sep 18, 2008 | 02:16 PM
mjr46's Avatar
mjr46
Originally Posted by jtmustang
even if your just swapping in a carb motor, as after the first of the year i will be looking for a 4cyl. coupe to throw a carb motor in
is that just so you can swap in the different guage cluster?
no need to swap dash harness if your plans are for a carb motor and you can use the 4cyl gauge cluster and long as you use a 4 cyl oil sender unit and the temp gauge will function fine with a 5.0 sender and the gas gauge and volt gauge won't be affected , you'll need a 5.0 tac and I'd get a 140 mph speedo while at it too
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
treesloth
Sep 28, 2015 07:03 AM
mrappe
Sep 26, 2015 10:16 AM
