can somebody plz help me...
Old Sep 24, 2008 | 03:13 PM
Shelty's Avatar
Shelty
your better off getting a Crane Hi-6 ignition kit or the Mallory unit you wanted. MSD is a little overrated imo
Old Sep 25, 2008 | 08:39 PM
mustangsneverdie's Avatar
mustangsneverdie
so I didn't tell ya'll what happened to me yesterday I was changing dizzys and the oil pump shaft came out with the 1st one so when i was puttin the other dizzy in I used a little piece of shop towel and stuck it in with the shaft well when I started to put the dizzy in the shaft his the side and fell into the oil pan I swear to you I have no luck I was almost tempted to get a lighter and just set it on fire
Old Sep 25, 2008 | 09:24 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
looks as if the retaining ring that locks the shaft in place is gone or missing.......next time using a pen magnet put the shaft in place first then install dizzy, drag a heavy duty magnet along the bottom of the pan and maybe you can work it out the drain plug hole
Old Sep 25, 2008 | 10:03 PM
mustangsneverdie
got a timing cover gasket set today and took off the timing cover to get it out got everything back together tonight all I have left to do is change the oil again run the wires back to the module and the rad and so forth just little stuff
Old Sep 25, 2008 | 10:05 PM
mjr46's Avatar
mjr46
have fun
Old Sep 25, 2008 | 10:09 PM
mustangsneverdie
I'll try and hopefully won't mess anything up this time around
MusBBad95
Aug 17, 2015 09:39 PM
supertrooper4
SVT Forums
Sep 18, 2004 03:24 PM
mustang_2004_65
Oct 21, 2003 11:18 PM
