spool questions
Old Oct 2, 2008 | 12:01 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default spool questions
i've already asked about this once but im going to ask again.
my neighbor has a fairmont with a built 302 and he runs a spool in the rear.
well when i rode in it the otherday to go to a car show i noticed it doesnt scrub or suff or squeal the tires around corners. i was told for sure it would. is it just the design of his suspension or what?
if i pul a strange spool, c clip elim. kit and axel kit....will i need to worry about scrubing, scuff or squealing of tires?
this isnt a daily driver, its just a fun car, weekend warrior and occasional track time. whats your input?
Old Oct 2, 2008 | 12:14 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
IMO, since it's not a heavy track car, I would spend the money elsewhere. Is your current rear beefed up at all now?
Old Oct 2, 2008 | 12:20 PM
FivePointOhh
in limbo
stock carrier, stock axels. 3.73's and new bearings. i'mtrying not to spend a tonnnn of money on the rear but ille doing some pretty hefty launches this coming up spring.
one reason i ask is the kit is only $650 for spool, c clip eliminator, and 31spline axels. it cost just that for a eaton/detroit locker, then you have to buy everything else.
what would be your suggestion?
Old Oct 2, 2008 | 12:32 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Do you know what's involved w/ installing the eliminators?
Old Oct 2, 2008 | 12:34 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
31 spline diff w/ carbon fiber clutches 240.00 from BOI. Alloy brand axles from Summit, 225.00. You're ahead by 190.00
That's what I'm running.
Old Oct 2, 2008 | 12:50 PM
WhiteWindsor's Avatar
WhiteWindsor
I had spool on my other car. I'm much happier with my current set up which is eaton chunk and 33 spline mosers. I also had eleminators on the other car.....nearly impossible to keep from leaking. I pulled the axle several times and it would still leak.
Old Oct 2, 2008 | 01:07 PM
WhiteWindsor
Forgot to add that you have to cut the housing ends also.
Old Oct 2, 2008 | 01:41 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
a well bit trac loc will always hook 2 wheels up!!
Old Oct 2, 2008 | 01:51 PM
ctgreddy's Avatar
ctgreddy
i've got an explorer 31 spline tlok and yukon axles. all together including the 4.10's i bought i have less than 450 into my rear end. I have yet to install it but i'm sure it'll last through the abuse i'll be dishing out.
Old Oct 2, 2008 | 01:59 PM
FivePointOhh
in limbo
im really liking the way this set up is sounding.
i thinking of hittin this project while i convert ot disk in the rear.
yea the c clips eliminators dont sound fun. i was readin up on them while posting about this thread, seems like a lot of people dont like them.
