wax polish compound..
Old Oct 3, 2008 | 07:34 PM
ponyboy302's Avatar
ponyboy302
Default wax polish compound..
can anyone tell me the differance or when to use them .. im trying to ged rid of the swirls .. someone mentioned some 3 m stuff but i couldnt find it .. is there any stuff i can get from a local strauss or pep boys .. what should i get ? i heard meguires color x is a good wax ???
Old Oct 3, 2008 | 08:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
meguiares makes a swirl remover, and is applied by a buffer and foam pad, wet sanding and then using a polish will work to...to get a glass finish
Old Oct 3, 2008 | 09:23 PM
NoGo95GT's Avatar
NoGo95GT
Meguires makes good stuff, it is what I normally use. Also check out obsessive detail. I've seen the end result on some of their cars, and it's really impressive. It's not too pricey either.
Old Oct 4, 2008 | 07:18 PM
80'smusclecarfan's Avatar
80'smusclecarfan
Dude your car looks fairly polished already. #1 deoxidize,I use acetone but DONT do it unless you know whats goin on.#2 work paint machine buffer.graduating foam pads usually 2 or 3 different works such as cutter/polish/final polish.Anyway waxing somtimes adds scratches for me and I dont do it. Meguires is a decent product... 3m is unsurpassed sofar in my limited exp.Can be found at autobody supply shops.
Old Oct 4, 2008 | 08:08 PM
OnyxCobra's Avatar
OnyxCobra
You apply the compound (usually 1000 or 1500 grit) with a buffer to remove anything in the paint the regular polish wont take out, after the compound you use the polish (with the buffer) to bring the shine back up, then wax by hand seals in all the goodness. It takes a little time.
Old Oct 5, 2008 | 11:51 AM
Timspony's Avatar
Timspony
SVT Section Moderator
I had the same color fox for 17 years...so I know it well!...You need to apply a good pre-wax cleaner, sealer glaze & a good wax....My process was to put on WET and take Off WET, panel by panel...That's the key!
Mothers makes a good product as does Meguires (NX 2 wax)....recently I added the Wet Obession ($50 BUT worth it!!) to my '03 Cobra...Looks great! ...I would not use a buffer on your paint as you do not have a clear coat and you could burn your paint if your not careful
Old Oct 5, 2008 | 08:27 PM
86HOGT's Avatar
86HOGT
They only way to get rid of swirl marks is to buff it with a wheel the right way like said above. A good foam pad, and 3M makes a compound called swirl remover.
Old Oct 6, 2008 | 08:18 AM
sowaxeman's Avatar
sowaxeman
Retired Moderator
What he said. Compound first for the cutting action, polish 2nd for bringing back the luster to the paint, and wax last for the top layer protectant. If you can't find the good stuff locally or still have questions then jump over to the detailing section and PM Justin from Obsessive Detail (juztang)....he is VERY much recommend and gets major props from everyone he sells/talks to. His products are a step above OTC and are priced right...and he sells all the tools to.
tmdm
May 2, 2021 02:49 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
baddog671
Jul 26, 2016 01:20 PM
folivier
Sep 26, 2015 02:28 PM
Sep 10, 2015 08:39 PM
