roller rockers
Old Oct 4, 2008 | 08:27 AM
mustangsneverdie's Avatar
mustangsneverdie
Default roller rockers
what would they do for my car. I have ported and polished E7's, E-303, and performer Edelbrock intake. I'm thinkin of goin with 1.6 rollers from crane but don't no if it would be worth it to go with them or just stay with my stock rockers. I've heard they could add up to 30 horses from stock
Old Oct 4, 2008 | 08:44 AM
Timspony's Avatar
Timspony
SVT Section Moderator
stock rockers are stamped 1.6...I have never heard of anyone picking up 30 hp with 1.6 roller rockers alone....I'd stick with the stockers
Old Oct 4, 2008 | 10:05 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
https://mustangforums.com/forum/5-0l-general-discussion/393439-bolt-on-myths-destroyed.html
If you look at the first test it is with stock vs 1.7's and the car didn't gain much hp as a peak but it was higher through out the range. They will allow the motor to rev up/down smoother and a little quicker. Stock rockers flex and are not exactly 1.6 all the way around. Some are a little bigger and some are a little smaller do to the flexing.
I would get a set of 1.6 RR if I had the cash to do so.
Old Oct 4, 2008 | 10:08 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
free's up stress on your valve train in a stock application. not much of an HP gain...more of an over feel for the car. it should rev a little better and stay more consistant in the upper RPMS.
personally i'd save your money and get some better heads.
Old Oct 4, 2008 | 11:06 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
30 hp ehh from roller rocker??? 6-8 maybe if that..you won't notice the increase
Old Oct 5, 2008 | 12:07 AM
.boB's Avatar
.boB
Generally speaking, RR's provide a benifit when valve lift gets to about .500". After that, the side loads from the sliding rocker tip deflect the valve stem and wear the guide. Below about .500", there's no benifit at all. The E303 cam has .498" of valve lift. So you're right on the edge there.
Stock 5.0's can generally pick up a little power by adding 1.7 rockers, like from a Cobra engine. That will give you more valve lift and a couple more degrees of duration. On some engines that's noticable. And on some it's not.
But you already have an aftermarket cam with additional valve lift. Increasing valve lift without claying the pistons is probably not a good idea. If you clayed them with the new cam, and you're sure about how much clearance you have, you might want to risk it. Then again, you might not.
Old Oct 5, 2008 | 08:17 AM
mustangsneverdie
hey that's what i read from crane
Old Oct 5, 2008 | 09:56 AM
Explosive's Avatar
Explosive
Crane says 30HP ? wtf ?
Old Oct 5, 2008 | 10:35 AM
mjr46's Avatar
mjr46
key wording they most likely use is: "up to", but whose to say when used with supporting additional mods that they aren't contributing also to the 30 hp claim??
Old Oct 5, 2008 | 07:33 PM
mustangsneverdie
idk I'm retarded that's why I'm in skool for it now
