TPS adjustment
-grab a multi-meter
-turn the car to the *on* position, not started
-place the positive on the green wire of the tps and negative wire to chassy or a grounded location
-and your multi-meter should read anywhere from .6 to 1.01 volts....preferably around .98 and .99
-if it does not loosen the two hold down screws and turn it back and fourth until you read your desired voltage.
-sometimes this wont work and you'll have to widen out the holes the screws go through to make more turning room, but most of the time not neccessary
good luck
good luck
