Dose this sit to high
For having a engine in it.
I think it dose but i have never looked at a stock 5.0.
*New Paint Cherry Red
*Built Motor
* 5 Speed
*New Suspension
* Needs Clutch Adjustment
And how do you do a clutch adjustment
*Built Motor
* 5 Speed
*New Suspension
its hard to tell because you cant see how big the sidewall is on the tire. The stock clutches on foxes are self adjusting so unless it has an aftermarket clutch quadrant/clutch cable, you are not adjusting it haha. BTW who puts NEW stock suspension pieces on foxes anymore I mean their is SO many alternatives haha! Looks clean though
i adjust my clutch like this. look up underneath the dash near the gas pedal, there is a white gear with a hook looking thing on it. press it up one click and check your clutch to see if it picks up where you want it. each click will make the clutch pedal release further from the floor. repeat if necessary. if you press it up too many clicks, you can pull the clutch pedal up to reset it.
