How hard is pulling the motor?
Old Nov 6, 2008 | 02:17 AM
Hollister Hoodlum's Avatar
Hollister Hoodlum
keep in mind you might turn it into a bigger project than planned like i did, i started out with just wanting to put my 88 block in. then it turned into a hey i want my block and everything else to look pretty too. So the original few weeks plan turns into a few months plan. not that thats a bad thing, just keep that in mind... =D
Old Nov 6, 2008 | 02:50 AM
83gtragtop's Avatar
83gtragtop
Why do you need to pull the motor...I don't think painting the bay is that big of a deal unless your going to also go to the effort to hide wires and such.
Old Nov 6, 2008 | 04:01 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Originally Posted by DeltaElite121
I am guessing the labor for a yank and reinstall would be something like $2500-3200 take or leave a few bucks. That's what I've seen anyways.
lmao wtf, i think you mean 200-300 for 2500$ ill drive to your house to pull it. hell id paint you car if it was prepped and cut and buff it afterwards lol
Old Nov 6, 2008 | 07:52 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
200...300 = not even close...to remove and and install a complete long block with transfer of all necessary parts from old motor onto new motor ..from start to finish =15-20 hrs ..pending on labor rate can range from 1200.00 to 1500.00
Old Nov 6, 2008 | 08:36 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well here in ga it would run you about 300 on something simple like a 5.0 :P
Old Nov 6, 2008 | 08:40 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
i think even i'd charge more than 300 to pull a friends motor if he had me pull it and replace it for him. and MJR knows i dont charge much
Old Nov 6, 2008 | 09:10 AM
RVC's Avatar
RVC
If you have never done it before and the motor is going to be out for a while make sure you bag and tag everything. Mark all your connectors with masking tape and number them. Use a digital camera if nesscary. These few things will ease re-installation and chop of some time....especially if you forget where things go!
Old Nov 6, 2008 | 09:35 AM
mjr46's Avatar
mjr46
for some one doing it on the side maybe...but I wouldn't even do it for that cheap on the side for grunt work
Old Nov 6, 2008 | 10:01 AM
RVC's Avatar
RVC
Here in Va Beach you would have to give a kidney, or your first born. Both in some places.
Old Nov 6, 2008 | 10:54 AM
DeltaElite121's Avatar
DeltaElite121
Originally Posted by mjr46
..is that so???? FYI....not everyone has the ability or know how to do a proper repair in their backyard, nor is every car like the 5.0.....so we'll leave it at that..........as for pulling the motor the degree of difficulty for one will depend on your mechanical knowledge/capability and access to the necessary tools to perform such a repair, if you have a motor that is ready to pop in that needs no distributor timed up then installing a motor will be as simple and unbolting the old one and bolting in the new one and bleed the cooling system and making sure you reinstall the new motor with all connections and grounds back in the same places
You're not telling me anything new, haha. Not everyone has the time, or place to work on it either so obviously the only thing they have to offer in exchange for the two things they lack is money. Assuming you want the job done right MOST shops will run you quite a bit, and that's just part of the business. You're paying for experience and a guarantee of quality work, and that's never cheap in any business... and the auto world already isn't cheap.
