How hard is pulling the motor?
Old Nov 5, 2008 | 12:21 PM
Pietrasz4's Avatar
Pietrasz4
Default How hard is pulling the motor?
How hard is it to pull the motor out of a 91 GT? I talked to a guy about paint and he said Id have to pull the motor myself. What does it intale and how long would it take? I guess you can say im not the most mechanically inclined person...
Old Nov 5, 2008 | 01:18 PM
Pietrasz4's Avatar
Pietrasz4
Also if I were to take it to a shop to have them remove and reinstall it how much would they charge?
Old Nov 5, 2008 | 01:24 PM
DeltaElite121's Avatar
DeltaElite121
I am guessing the labor for a yank and reinstall would be something like $2500-3200 take or leave a few bucks. That's what I've seen anyways.
Old Nov 5, 2008 | 01:43 PM
94Yellow50's Avatar
94Yellow50
i would say anyone on this forum would be able to pull a motor out of a fox lol...because its not hard at all..basic tools and a engine hoist...which is significantly cheaper than those figures^^...and i guess the hoist isnt 100% necessary because ive pulled motors before without one..but just find someone with one and borrow it...really tho its just connectors, couple hoses,exhaust, undoing the motor mount bolts, depending on if trans is coming out or not undoing that...me personally id just remove driveshaft, and pull engine and trans as one..its really not tough even for the least experienced person
Old Nov 5, 2008 | 01:52 PM
DeltaElite121
It's just time consuming. That's about it. I would do it myself, also. Shops gut you out of your money hard.
Old Nov 5, 2008 | 02:41 PM
94Yellow50's Avatar
94Yellow50
also forgot...its not necessary..but it does make it nice if you just remove the hood too..make some marks so you know where the hinges are an just have someone help you lift it off..in my expierences as long as nothings completely rusted solid..its nothin you shouldnt be able to handle in a night.
Old Nov 5, 2008 | 03:56 PM
Shelty's Avatar
Shelty
its not hard, just take forever, and make sure you position the AC and PS pumps out of the way... you dont wanna discharge the system...
Old Nov 5, 2008 | 04:46 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
coulpe of vac lines, coolant hoses, few electricle connections, fuel lines couple of mechanical connections(clutch throttle ect.) exhuast, motor mounts trans mounts and remove drive shaft. couple hours and a few beers later and its out
Old Nov 5, 2008 | 06:54 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
..is that so???? FYI....not everyone has the ability or know how to do a proper repair in their backyard, nor is every car like the 5.0.....so we'll leave it at that..........as for pulling the motor the degree of difficulty for one will depend on your mechanical knowledge/capability and access to the necessary tools to perform such a repair, if you have a motor that is ready to pop in that needs no distributor timed up then installing a motor will be as simple and unbolting the old one and bolting in the new one and bleed the cooling system and making sure you reinstall the new motor with all connections and grounds back in the same places
Old Nov 5, 2008 | 09:05 PM
jtmustang's Avatar
jtmustang
get a buddy or 2 one with a cherry picker and then supply some beers and pizza and it will be out in a few hours
and btw why are you repainting?
