question
Old Nov 8, 2008 | 11:03 PM
oompa's Avatar
oompa
Default question
I just put a b303 in my car and it seems to flood out a little it that normal? also I took a cobra intake off and put a trickflow on and at certin times the intake seem to wistle? I thought it was a vacume leak but I cant find one are they suposed to do that? and thanks for the help.
Old Nov 9, 2008 | 02:02 AM
mattdel's Avatar
mattdel
i doubt its a flooding issue, more like you're not used to the different cam pattern. unless the problem is more than your description.
the whistle is normal for certain intakes, i've never seen it described with a trickflow, but nevertheless dont worry about it.
Old Nov 9, 2008 | 08:41 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
some throttle bodies and intakes have sharp edges/ rough casting and cause the airflow whistle...as far as it flooding, what makes you draw such a conclusion??
Old Nov 9, 2008 | 12:27 PM
saleenpride1986's Avatar
saleenpride1986
I found this link a few weeks ago. There is a whining noise in this video and was wondering if your 'vacuum leak' sounded like this. This noise is from his throttle body but i have heard intakes make a very similar noise to it.
http://www.dropshots.com/88bluegt#da...09-28/20:46:14
Old Nov 9, 2008 | 01:23 PM
oompa's Avatar
oompa
yep that is the sound. and I think it is flooding beacuse somtimes it will quit and it is hard to start back you can also smell the fuel.
Old Nov 9, 2008 | 02:03 PM
calfroper_06's Avatar
calfroper_06
that sound like maybe a timing issue. whats your timing set at
Old Nov 9, 2008 | 02:22 PM
saleenpride1986
Well, by smelling fuel doesn't always mean your flooding. that whining noise can be a vacuum leak or like mjr previously stated, some have sharp edges and rough castings which can cause the noise.
while youre there, check to make sure the pressure reg isn't leaking while your checking it out if you smell fuel, and check the rails/injectors. see if theres gas just chillin anywhere!
Old Nov 9, 2008 | 04:10 PM
mjr46's Avatar
mjr46
you need to verify if it has spark or lack of fuel when it won't start back up immidiately, that could be a sign of a bad stator or tfi module and the test port on the fuel rail really should be put to use, I'd invest in a FP gauge so you can monitor FP when prob occurs, you need to isolate prob to a system
Old Nov 9, 2008 | 07:14 PM
oompa's Avatar
oompa
thanks for all the help.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
