Quesion about motor size
It's a sb 5.8L 351W base STROKED to 408ci....(W)indsor = small block (C)leveland = big block...way way too much money to stroke a 351C
...If you have concerns, pass, or find a 351W person...
well if hes already taken the 351 and stroked it to a 408 thats about the most it going to go. the really only way to check the motor would be a compression test. my Father in law as a 68 with a 408 and that things a beast, power wise its very nice, but the condition of the rings and what not would be how hard its been drove. if you get it just make sure it has a good cooling system
if you crack the block or something most likely you could still use most of the stroker kit, rods, crank whole top half of motor, worse comes to worse youll have to find a new block and bore it and get it ready for the stroker kit and maybe some new pistons, really all comes to what could go wrong. But the could is what might not happen and you would have a killer stang with a mean motor.
if your scared to buy it like that you could build one your self, buy the time you get another car to the shape that one might be youll be over what he was asking, its your call
And I'm not too familur with building cars, so I wouldnt really feel like trying to do a full rebuild on my first try. Something like a bike is no big deal, but its 1000 times more simple to rebuild a bike! My worry I guess is coming from seeing 2 strokes lockup and chew the walls of the cylinders, and they got to be bored out. You can go several bores, but its not uncommon to see someone selling a motor that they claim is very reliable and fresh build and all that and the thing fails and its already bord to its max, and now the cylinders are no good. I am also thinking of the motor in the car wrong too. I keep thiking of it as having a top and bottom end rather then the bottom end holding the cyliders and crank.
Clevelands are small blocks and cost a few 100 bucks more for a rotating kit. Myths abound..............
Yup, and thats unfortunatly learned when building my bike, I built it 3 times before I got it 100% the way I wanted it. Lots of wasted money. So I am asking questions about the car now so I dont do it again.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
10-05-2015 06:07 PM
09-03-2015 07:14 PM
