battery relocation
Old Dec 4, 2008 | 12:28 AM
mustangsneverdie's Avatar
mustangsneverdie
Default battery relocation
How did ya'll run the battery cable.Did ya'll hide it so it wouldn't get hit by nothing while your going down the road or did ya'll leave it exposed that way if something happened to it you could get to the wires and I can get 4 guage wire from work do ya'll think that's thick enough
Old Dec 4, 2008 | 12:57 AM
primetime5.0's Avatar
primetime5.0
I just left mind under the car, 4 gauge is to small
Old Dec 4, 2008 | 02:38 AM
q8stang's Avatar
q8stang
dont want to hijack but where do you connect the cables ? exact same places as they were?
Old Dec 4, 2008 | 02:47 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Alot of people bring the solinoid to the rear as well and the ground will be mounted on the rear frame (not the flimsy body). Other than that yes.
Old Dec 4, 2008 | 08:13 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I ran mine inside the car. Used 00 gauge. As Prime stated above, 4 gauge way too small. I left the solenoid under the hood. Too much wiring to move.
Old Dec 4, 2008 | 08:44 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
ran my 1gauge wire through the car and poked it out behind the drive side fender at an existing exit point /w grommet.
Old Dec 4, 2008 | 09:19 AM
Portmaster's Avatar
Portmaster
Battery and box mounted passenger side of trunk, 00 cable under car along frame connectors, solenoid mounted stock location to keep away from heat. I don't like mounting the solenoid in the trunk because it increases to load on the solenoid dramaticly. Even though I'm using a Powermaster Starter with soliniod I'll tie the energizer wire to the Cable post on the starter and wrap the starter in Thermowrap and use a Ford Style solinoid. having Big Cubic inch engines teaches you what works. I had this same set up on my 540 Street Chevelle (Ford Solenoid and all) and never had a cranking problem. I like the Solenoid in the stock location because it is away from the header heat, allows me to use a remote starter button easy, gives me a good power location an allows me to run the the Cable from the Solenoid to the starter along the oil pan rail where it stays cooler. I'm all for a pretty, clean engine bay but not at the cost of pulling up to get gas only to have one of my cars not to crank. If that happened and any of my buddies were there when it happened they would run a add in the local paper in the announcement section to let everyone know that my car wouldn't crank just to get a laugh. When one of my cars break I never hear the end of it, lol
Old Dec 4, 2008 | 09:33 AM
nseoi's Avatar
nseoi
close up pics would be a good help i think, anyone?
Old Dec 4, 2008 | 10:46 AM
BB Service's Avatar
BB Service
Banned
00 gauge welding wire is the only way to go when relocating your battery. Don't forget the battery cutoff switch. You'll also have to run the alternator wire to the switch if you want it to turn the car off correctly.
Old Dec 4, 2008 | 01:38 PM
crusin92red5.0's Avatar
crusin92red5.0
Where do you get this 00 welding wire? HOme depot?
