Supercharger or Turbocharger?
#21
so basicly if you want to have more fun you buy a roots/twinscrew.
If you want to be faster you buy a turbo.
thats the super simple version that I have gotten out of all of this.
I think I would go with a s/c, but then again I plan on keeping my baby n/a this time around.
#22
For the most part I agree with that. But depending on setup, you can have a fair bit of low speed leakdown with a roots or screw(if the blower is large for the engine) and lose some boost response as a result, and you can have a pair of very small turbos with a tiny a/r ratio that can respond quickly at very low rpm(but would be too small to make best top end power).
I like roots myself for their simplicity, but I wish more companies would start investing some technology into them. Most of them aren't as efficient as they could be.
If small turbo's are your thing, then by all means use them. I prefer turbos sized a bit on the large size for multiple reasons, but either way you're not going to get rid of lag even if you have a tiny turbo.
Turbo 5.0's have a near identical lag time as 4 cylinder, keep in mind most 4 cylinders turn higher rpm from the factory so they're generally fitted with a pretty big turbo & keep in mind you can't compare an aftermarket turbo kit on a v8 to a stock turbo kit that is poorly designed. While they are using 8 cylinders to push 1 turbo (if single kit) the turbo is larger.
#24
The bigger thing to look at once you get past the budget is this. Are you looking for a street car that sees the track once in a while, or a track car that sees the street once in a while.
Street car=Blower
Track car= Turbo
Its the same logic as having a manual for a street car, its just more fun on a day to day level.
Now, I have yet to see a turbo car with a turbo that is small enough to have next to no lag. Just for the fact everyone wants the power up top. Thus, larger hot sides and more lag.
Turbos will make more power, be more efficient yet, remember there are trade offs to getting that big turbo to make big numbers. If you want a turbo car and nothing else, get a hold of companies such as Turbonetics, they will set you up with a turbo based on your set up and needs. So, it will be fun to drive, with power on demand.
Street car=Blower
Track car= Turbo
#25
The single turbos on most Mustangs are not big enough to where they cause a lot of lag, and because you run all the exhaust through that one I've heard its not bad at all. I do not have personal experience but I can tell you it's not going to be like a 1000whp single turbo Supra.
#26
Street car=Blower
Track car= Turbo
Street car=Blower
Track car= Turbo
Of the turbo companies & people that put the most research into it, most will favor the twins for a road or drag race setup. A garrett technician also said that a single turbo is more efficient than two singles & while that is true keep in mind that's not considering the factors of the engine & exhaust setup.
#27
I want to chime in and ramble please allow me to be a little picky for a second! When asking if turbo or supercharged I smile because the question you are asking is really 'what type of supercharger OR supercharging would you recommend that i use' your parameters are *not n/a*
for example my 62 corvair is turbo supercharged, makes sense the turbo is the type of supercharger... the type of *not n/a* it says so in its manuals and when looking up in my dictionary/encyclopedia supercharging is general meaning over normal atm. I know people use "bling rims" instead of wheels even though the "rim of a wheel" and a "wheel" are different and the one that makes me laugh the most is "posi" is used for EVERYTHING even though a registered GM trademark for their LSD, ford uses trac-loc I know I know I just had to ramble and I apologize!
I would love to go for my street/fun/bracket car a simple single turbo but I never have found a legal kit, the only turbo legal 5.0 kit I have ever heard of is the defunct Incon Twin Turbo Kit,
http://members.tripod.com/tomak3/page5.html
you have to cut the body/engine bay and it IS two of them HOWEVER "You don't have to relocate your battery and your stock H-pipe bolts right up" which is a plus... If you can find the kits. I have been looking at the two new "Paxton Self-Lubricating Centrifugal Supercharger"
http://www.motorator.com/blog/hot-ro...l-supercharger
anyways those are my two favroite choices and I dont meant to offend with my ramblings but just bring up a point for a gag-and-smile ok
#28
many turbo kits are street legal, just not in here in CA where we have a visual and a sniffer test. some states just check to see if you have any codes and if you dont, you pass.
#29
only on 96 and above that criteria applies where the vehicle is obdII pre obd II require a treadmill test here and in most other states a tail pipe output test or however the IM240 TEST IS WORDED per state
#30
aahh i see. the only thing i know about smog testing is that a couple bills and my car passes with flying colors LOL
