what would it take?
Old Dec 21, 2008 | 10:10 AM
symonds86's Avatar
symonds86
Originally Posted by Portmaster
Dart Block 4.030
4340 Crank
Carrillo Rods
JE pistons
11.00-1 Compression (hey do have to drive it to the track, lol)
Dry Sump system
Edelbrock Chapman heads
Jessel rockers
Comp 300RXA solid roller cam
Super Victor intake
2 inch headers
1000 CFM QFT carb
PA C4, 5500 stall
5:13 gears
10,000 rpm tach
leave the Nitrous bottle at home, lol
and some work out back so she will leave the line, and not just make a cool tire cloud
Old Dec 21, 2008 | 10:18 AM
Portmaster's Avatar
Portmaster
I leave the suspension work to the Chassis guys. I know how to make GM A bodys hook but I'm on a learing curve for Fox Bodys. I'm not use to cars that tear themselves apart so easy, lol
Old Dec 21, 2008 | 02:33 PM
w8less's Avatar
w8less
Dart Block 4.030
4340 Crank
Carrillo Rods
JE pistons
Dry Sump system
Jessel rockers
Super Victor intake
2 inch headers
1000 CFM QFT carb
PA C4, 5500 stall
5:13 gears
10,000 rpm tach
you've got to be kidding me....
Old Dec 21, 2008 | 02:36 PM
Portmaster's Avatar
Portmaster
Yeah, I was. lol
But it would make some power though.
Old Dec 21, 2008 | 02:37 PM
w8less's Avatar
w8less
im not denying that.
anyone have worth while to add?
Old Dec 21, 2008 | 02:44 PM
Portmaster's Avatar
Portmaster
for me to beat a local guy?
specs:
86 coupe
tubular front suspension
drag lites 15x4 15x8
upr rear suspension
cowl hood
42x stroker
trickflow twisted heads with port work
flat tappet cam 600 lift not sure on duration
vic jr
750 carb
1 5/8 headers
c4 not sure size on the converter
not sure what else but it only put down 363 i believe on the dyno then close to 600rwhp on a 150 shot.
it runs 6.80's at the local 1/8th track with a 1.5 60ft time
__________________________________________________ _____________________________
now my question is what do i need to beat him?
i am hoping to have my car around 2700lbs with me in the car. i want to beat him with a 302/306 combo. i just want to show him what a well thought out car can do. so tell me what combo you would put together. my car will be a carb application and im sure nitrous will be in the works. MY only concern is i want to be able to drive my car to the track and back.
thanks Jasper!!
Give me a realistic dollar amount you want to spend on the "Virtual" engine. I can tell you it it won't be real cheap but his car isn't that quick for 600rwhp. What kind of Block do you want to use, transmission, rear gear?
Old Dec 21, 2008 | 03:18 PM
Portmaster's Avatar
Portmaster
Stock block, .030 over,4.100 chamfer.Studded mains, Main girdle, studded heads, Valley Girdles
Eagle 4340 forged rotating assembly 11.0-1
Victor Jr Heads
Comp XR292R solid roller with Comp EDM lifters
Victor Jr Intake
850 Holley HP DP
MSD Pro dist, 6AL 7800 module
PA C4, 3500 stall
4:56 gears
