lifting engine
Old Dec 21, 2008 | 06:39 PM
Berry94's Avatar
Berry94
Default lifting engine
im picking up my engine and my buddy is letting me use his engine hoist but the only time Ive used one was lifting a carb engine so it had the plate on the manifold and you just picked it up.this is a longblock 92 motor and wondering if there are hoist points or another way to lift it?thanks
Old Dec 21, 2008 | 06:44 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
stock motors if not removed had lifting eyelets on the passanger rear and driverside front headers
Old Dec 21, 2008 | 06:55 PM
calfroper_06's Avatar
calfroper_06
if the eylets are not there, they make a plate that fits the efi lower intake, or you can get some eyehooks at lowes or home depot and screw several in the lower intake ant attach with chains( if done this way be carefull and dont let the chains slip)
Old Dec 21, 2008 | 07:29 PM
Berry94's Avatar
Berry94
alright il look for them its bone stock and he pulled when ever he did so they should still be there thanks for the info
Old Dec 21, 2008 | 07:31 PM
mjr46's Avatar
mjr46
you won't be able to miss them the headers use a double stud and they are attached to that
Old Dec 21, 2008 | 08:06 PM
Berry94's Avatar
Berry94
thank you sir
Old Dec 22, 2008 | 05:02 PM
dillon1340's Avatar
dillon1340
are the aluminum threads in the lower intake strong enough to lift the engine? i've kinda always wondered that
Old Dec 22, 2008 | 06:32 PM
Joe67's Avatar
Joe67
Banned
i am sure they would be, i have some aluminum bolts that are tested for 30k psi tensile strength, and however many are on there, im sure it can lift a motor under a half ton
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Insidian
Carolina Regional Chapter
Sep 8, 2015 05:33 AM
