Vacuum Tree Help
Old Dec 29, 2008 | 02:16 PM
Tony71502's Avatar
Tony71502
Default Vacuum Tree Help
How much access is there behind the firewall/cowl sheetmetal? I installed a strut tower brace a while back and since the vac tree is slightly in the way, only 1 bolt is holding it in **** eyed. Im wondering how much room I have to work with(just to fit my hand and a nut) behind the cowl piece for when I drill 2 new holes about an inch higher than the stock vacuum tree location. I would take the cowl molding off right now and check but I'm at work and daydreaming about the toys.
I could probably just use sheet metal screws without bolts. There is nothing behind that the drill may damage is there?
Thanks
Old Dec 29, 2008 | 04:54 PM
Catchpole's Avatar
Catchpole
There isn't anything to worry about if you use just some Reasonably lengthed
screws.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 16, 2015 03:07 PM
TfcCDR
Sep 14, 2015 12:08 PM
