ported heads
Old Jan 12, 2009 | 09:34 AM
Portmaster's Avatar
Portmaster
Those heads bring back some memories
Old Jan 12, 2009 | 09:37 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
hopefully good ones
Old Jan 12, 2009 | 10:03 AM
Portmaster's Avatar
Portmaster
Originally Posted by FivePointOhh
hopefully good ones
Not really, lol I had a Falcon with a 289 that I raced. I did as much as I could do to it buying about everything Holman & Moody had on the shelf at that time and was getting my behind cut at the track. I moved from there into FE block Fords and then into Small Block Chevys. Thats when I started winning big time. It was hard to find a good set of heads back in the 60's and 70's. It wasn't so much that one engine was better than the other but more a parts availablity matter. Back then Pontiac engines were a more popular engine to build than a 289.
Old Jan 12, 2009 | 10:30 AM
FivePointOhh
in limbo
i see... yea, shouldnt be an issue here. not tryin to win events or anything, just achieve a goal.
Old Jan 12, 2009 | 03:13 PM
302army187's Avatar
302army187
you spent that much money on e7's?
...**face palm**
hey hey hey now, Theres alot of work done to em, and i think i got my money's worth.
plus when i move up to some AFR's or Trickflows, i can put these on my '96 Bronco!
Old Jan 12, 2009 | 03:17 PM
FivePointOhh
in limbo
ugh...
GOOD GOD MAN, YOU SPENT 500+ ON STOCK E7'S!!!
Old Jan 13, 2009 | 08:47 AM
FivePointOhh
in limbo
this may be a stupid question but since the large valve seats will be cut soon. do i work the bowls out now or after the new seats are cut? the reason i ask is because i dont want to risk ruining the new seat being cut. of course ill do the same as i did with the other ports. i made a jig to ensure i did not go larger than i wanted. but still...things happen. what do you guys says? work the bowls before or after the valves are cut in?
Old Jan 13, 2009 | 02:45 PM
FivePointOhh
in limbo
bumppppppppppppppppppppppp.
Old Jan 13, 2009 | 09:38 PM
FivePointOhh
in limbo
one last bump for possible answer
Old Jan 13, 2009 | 09:52 PM
ratrap1964's Avatar
ratrap1964
I would do the bowls now and rough in the seat area. After the seats are cut I would tape them and then blend them in.
