Got a vibration
Old Jan 16, 2009 | 08:35 PM
calfroper_06's Avatar
calfroper_06
Default Got a vibration
Im getting a pretty good vibration threw the shifter, it comes in at about 2k then gets worse after 3k rpms. its there in every gear and its very annoying. Just trying to get some pointers what to look for, im in the process of pulling tranny, what do i need to look for or check guys? thanks
o and with clutch in reving you cant feel it, u can feel the motor but no vibration, its bad in gear with a load or no load under it
Old Jan 16, 2009 | 08:37 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
trans mount?
Old Jan 16, 2009 | 08:39 PM
calfroper_06
looks ok but idk, if the tranny mount was bad shouldnt it vibrate just at higher speeds not at a certain rpm
Old Jan 16, 2009 | 08:43 PM
Tberg725's Avatar
Tberg725
Check to make sure the bolts on the driveshaft are tight mine have came lose a couple times, same thing happened.
Old Jan 16, 2009 | 08:54 PM
calfroper_06
all were tight actually broke one of my wrenches getting them off, damn gears installers lol
Old Jan 17, 2009 | 08:03 AM
calfroper_06
any other suggestions
Old Jan 17, 2009 | 09:08 AM
projectresto83
M.A.D. Motorsports
When is the last time your clutch was replaced?
Put the rear of the car on stands and pull the driveshaft out then put a bag on the end of the tailshaft(for leaks) and see if there is still a vibration when in gear.
Old Jan 17, 2009 | 10:33 AM
Timspony's Avatar
Timspony
SVT Section Moderator
Ujoint?
Old Jan 17, 2009 | 11:25 AM
projectresto83
M.A.D. Motorsports
Originally Posted by timspony
Ujoint?
The reason why I said pull the driveshaft and see what happens.
Old Jan 17, 2009 | 11:38 AM
WhiteWindsor's Avatar
WhiteWindsor
By this comment i'm assuming you recently had gears installed. My money is on the pinion gear not being spec'ed within tolerance's. Grab the back of the drive shaft near the diff and see if you have any slack while pushing and pulling the driveshaft (in and out). Could have something to do with the crush sleeve not being crushed or overtightened. The first time i installed gears i had the same problem. Very bad vibration...almost violent during certain rpms. My problem was what i stated above, i fixed it and it ran great. If you do have play take it back to where you got them installed or just take it back anyway and tell them your problems....all this is assuming you paid someone to install gears recently.
