intake/heads question
Old Feb 7, 2009 | 03:37 PM
LiL3viL's Avatar
LiL3viL
Default intake/heads question
Im trying to get all the parts together for a heads and cam swap, im going to install an e-cam and gt-40p heads. i know that this is probably a stupid question but i was wondering if i needed a gt40 lower in order to work with the heads? this will be my first time doing this kind of thing so im lost on what will work or not
thanks in advance
Old Feb 7, 2009 | 07:25 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
no, any 302 intake will bolt up to the gt40 heads. but the lower intake and plenum must match.
if you dont have an E cam already id shop around for something else first unless you are worried about emissions.
Old Feb 7, 2009 | 10:42 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
no but I'd get a gt-40 intake / explorer set up= improvement over stock
Old Feb 8, 2009 | 02:33 AM
LiL3viL's Avatar
LiL3viL
thanks for the replies guys, the only reason why im going with an E cam is because my brother gave it to me when he gave me his car, same with the heads. so far ive bought 1.6 rr, new lifters and pushrods for the build. i would get a gt40 intake right now but im going to use that as my senior project in autos class so im trying to put that off for a bit, as weird as that sounds lol.
Old Feb 8, 2009 | 07:21 AM
mjr46's Avatar
mjr46
hey whatever works for a grade
Old Feb 8, 2009 | 07:50 AM
Timspony's Avatar
Timspony
SVT Section Moderator
...Nothing wrong with the E cam...$$$ was right! ...I'd agree, get a Cobra GT40 intake, look used if the budget is tight!
Old Feb 8, 2009 | 01:40 PM
LiL3viL's Avatar
LiL3viL
haha yeah exactly
im definately going to get a new intake, probably a gt40 unless i run into some money and can afford like a trick flow or something along those lines. after i graduate im planning a 347 stroker build already.
oh another question for you guys, what would be a good clutch to get? mine is slipping terribly and after i get the swap done i know im going to explode it lol
Old Feb 8, 2009 | 03:30 PM
w8less's Avatar
w8less
did you change the springs on the heads?
Old Feb 8, 2009 | 03:37 PM
LiL3viL's Avatar
LiL3viL
yeah sure did, Comp Cams Springs/Retainers/Valve Locks
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
