high idle problem
Old Feb 7, 2009 | 06:57 PM
Stangnsnow2's Avatar
Stangnsnow2
Default high idle problem
i have a 88 gt with a cam speedpro pistons supercharger and some other things here and there, i cant get my idle to be any less then 1200 or 1100rpms. also when i rev it or take it out of gear it stays at a high idle and slowly comes back down to the 1100rpm...any ideas on how to fix this? i adjust the distributor but the idle just flattens itself out to the 12-1100rpm range after a few seconds.
Old Feb 7, 2009 | 07:13 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
check tps voltage and then set base idle IAC disconnected when doing so.
Old Feb 8, 2009 | 08:33 AM
dillon1340's Avatar
dillon1340
it could be idling high because it thinks it has to. is there a check engine light on? has it always done this? mine did it one time and cleaning the air idle valve fixed it.
Old Feb 8, 2009 | 10:28 AM
Stangnsnow2
ok well it is probably the tps because i think the dumbass that had the car before me striped the screws in to it and i tryed ti get it out one day and said f* that, so i guess ill just have to drill and tap them out today, thanks again
2007StangV6
Jan 28, 2016 06:09 PM
Oct 5, 2015 06:07 PM
Emblazoned
Sep 3, 2015 10:45 PM
Sep 3, 2015 07:14 PM
5.0 kevo
Sep 3, 2015 06:24 PM
