quick question!
Old Feb 21, 2009 | 09:52 AM
Portmaster's Avatar
Portmaster
Originally Posted by mjr46
I believe in using custom cams, but you can get some decent ots cams, comp xe series cams are good, I had an xe282 in my stroker that worked good until I went custom, so we'll see how that works here in a few weeks
Let me know if you want to sell your XE282. I have a buddy doing a real budget build that could use it
Old Feb 21, 2009 | 11:24 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I'd like to reuse it in the 306 domed piston short block that used to be in my 85 before the stroker install, I'd like to find a 89-93 gt vert 5 spd mass air car to install it in but all that hinges on selling my 66 and 92, some one is looking into buying my 66 so by mon or tuesday I'll know if my future plans will hold up
Old Feb 21, 2009 | 07:36 PM
boosted AWD's Avatar
boosted AWD
Comp Cams NX264HR. Will work really well with the GT40 heads and Nitrous. I'd back that shot down to 100 if you still have the OEM pistons.
Would you say it runs better than a tfs1?
Do i really need to back off to 100hp? i thought these internals were strong enough to handle it?
Old Feb 21, 2009 | 07:43 PM
Portmaster's Avatar
Portmaster
Yes, it's better suited to your heads and Nitrous. 5.0 stock internals are overated.
Old Feb 21, 2009 | 07:49 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
not to contradict what you are sayin but ive seen more than a handful of people spray stock bottom ends 100+ shot. i think quarterhorse has a 150 hit on his fox right now runnin 11.30's.
not sayin its a good idea but oem pistons are fine with the nitrous. i bet the c-rod bolts will stretch long before the pistons let go if its tunes right.
Old Feb 21, 2009 | 09:32 PM
mjr46's Avatar
mjr46
oem pistons 85-92 are forged and fine to spray no2 on
Old Feb 21, 2009 | 11:19 PM
boosted AWD
I'm still not sure how to tune everything when it's all said and done... do i just put some 24# injectors and a 255lph fuel pump in and take it to someone and get it dyno tuned as is? Or do i need to buy a new computer, fpr, etc?
Old Feb 22, 2009 | 01:32 AM
Alex-7's Avatar
Alex-7
Yes!
Old Feb 22, 2009 | 05:31 PM
boosted AWD
Originally Posted by Alex-7
Yes!
i don't need to convert to maf or anything?
Old Feb 22, 2009 | 06:12 PM
Alex-7's Avatar
Alex-7
Woops! yeah I forgot you had a SD Car.
I'd def convert to maf, But I think the deal with SD is you CAN have a chip burned for it to make it run right with your mods. But it'll run like total **** until you do. Then if you ever change anything, you'll have to have another chip burned for it......
I think anyway, don't fully understand how SD works.....
