quick question!
Old Feb 20, 2009 | 11:26 PM
boosted AWD's Avatar
boosted AWD
Default quick question!
gt40 (explorer) heads and intakes, tfs1 cam, 150 shot... Is this a good setup?
I'm sticking to those heads and intakes and the nitrous... I'm pretty much just asking which cam i should run.
I don't care about sound/lopeyness, Just whatever will fit and give me the most power!
Old Feb 21, 2009 | 12:47 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if you run the tfs cam which is an okay cam for an OTS make sure you run matching valve springs and hardware on the heads
Old Feb 21, 2009 | 01:38 AM
Alex-7's Avatar
Alex-7
Good setup.
You'll get a nice sound/lope with it. and a decent idle.
Old Feb 21, 2009 | 01:58 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
+1
but yea whatever you choose make sure you you support it correctly.
Old Feb 21, 2009 | 08:54 AM
boosted AWD
well if it's only an okay cam then what's a better cam? I know nothing
how do i know what hardware i need to install in the heads?
also, is it worth the money to have the gt-40 heads ported and polished?
Old Feb 21, 2009 | 09:37 AM
mjr46's Avatar
mjr46
if it doesn't cost you alot to port the heads go for it
as far as hardware for heads here:http://store.summitracing.com/partde...rt=TFS-2500100
Old Feb 21, 2009 | 09:40 AM
Timspony's Avatar
Timspony
SVT Section Moderator
Ported GT40 heads worth the $$$$
Old Feb 21, 2009 | 09:45 AM
boosted AWD
sweet, thanks for the help guys!
but no one can think of a more awesome cam that'll fit with the gt40's?
Old Feb 21, 2009 | 09:48 AM
Portmaster's Avatar
Portmaster
Comp Cams NX264HR. Will work really well with the GT40 heads and Nitrous. I'd back that shot down to 100 if you still have the OEM pistons.
Old Feb 21, 2009 | 09:49 AM
mjr46's Avatar
mjr46
I believe in using custom cams, but you can get some decent ots cams, comp xe series cams are good, I had an xe282 in my stroker that worked good until I went custom, so we'll see how that works here in a few weeks
