Easy out?
Old Feb 22, 2009 | 01:25 PM
1slomofo's Avatar
1slomofo
Originally Posted by Portmaster
Take a very sharp center punch and center it up on the broken bolt and give it a good smack with a small hammer so it will dimple the broken bolt. Then get a small drill bit (1/8) and then drill straight down the center of the bolt. Then keep moving up one size at the time until you start hitting aluminum. The most times you can use a pick to get the rest out or retap the hole. It normally take me about 30 minutes to do an extraction like that.
i agree with using a punch then drilling down the middle with the 1/8 bit.....after that use an ez out .I deal with alot of broken bolts on machinery i work with on the job. Start with a small bit and work your way up.Dont use a torch your just asking for trouble.
Just my $.02
Old Feb 22, 2009 | 01:44 PM
BlessedHellride's Avatar
BlessedHellride
Another option is, if there is anything of the bolt showing, drop a nut over top of it and weld the nut to the bolt, It will back out with ease with that much intense heat. I have done it many of times.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
baddog671
Jul 26, 2016 01:20 PM
TimeLord101
Oct 1, 2015 06:40 AM
Sixer4Life
Sep 29, 2015 07:03 PM
