Easy out?
Old Feb 21, 2009 | 05:49 PM
89musclestang's Avatar
89musclestang
Default Easy out?
I snapped one of my lower intake bolts and was wondering how good these easy out drill bits are... anyone with advice on this would be great...thanks
Old Feb 21, 2009 | 05:52 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
often find it's easier to drill and retap the hole, cause more often than not the siezed bolt won't come out once broken off
Old Feb 21, 2009 | 05:55 PM
93 LX FiveO's Avatar
93 LX FiveO
i would heat it up if u can before attempting to pull it out
once its hot, the ez-out should work.. just take your time with it
Old Feb 21, 2009 | 07:21 PM
94Yellow50's Avatar
94Yellow50
we did that when we were swapping my intake. if you have the lower off and iron heads, heat the head around the bolt..dont heat the bolt. heating the head expands it enough to crack the rust free sometimes. this is all if the lower is off tho.
Old Feb 21, 2009 | 07:36 PM
Portmaster's Avatar
Portmaster
Take a very sharp center punch and center it up on the broken bolt and give it a good smack with a small hammer so it will dimple the broken bolt. Then get a small drill bit (1/8) and then drill straight down the center of the bolt. Then keep moving up one size at the time until you start hitting aluminum. The most times you can use a pick to get the rest out or retap the hole. It normally take me about 30 minutes to do an extraction like that.
Old Feb 22, 2009 | 08:15 AM
89musclestang
alright thanks guys i was little frustrated yesterday when it happened, i didnt get the intake off yet so im hoping that it didnt break off in the block and i can get a hold of it with a vise grip, heat up around it and twist it out.....with luck
Old Feb 22, 2009 | 09:06 AM
AdderMk2's Avatar
AdderMk2
Banned
if you are going to be doing any kind of drilling, mask off the top of your motor with masking tape and newspaper.... and while drilling, have a shop vac going to suck up any little shards of metal that may come flying out..
Its always good to keep random shrapnel out of your crankcase
Old Feb 22, 2009 | 09:13 AM
89musclestang
yea i here you on that one thanks for the tip
Old Feb 22, 2009 | 10:01 AM
Portmaster's Avatar
Portmaster
If you have enough to hold onto with vise grips don't heat up the intake. Go to the parts store and get a can of Freeze Spray. Spray the area really good and wait about thirty seconds and shoot some WD-40 or PB Blaster (I love PB-Blaster) and wait a minute of two and it should spin right out. Never go towards a aluminum intake with a torch. If you do it on the car use some masking tape to tape the intake passages to keep stuff from droping in your engine
Old Feb 22, 2009 | 10:27 AM
89musclestang
oh no i would never do that to an intake its in the block tho so hopefully there is enough to grab hold of and twist it out....pb blaster is good stuff lol
