Traction PLEASE!!!
Traction PLEASE!!!
I have an 89 gt slightly modified ( cold air, GT40 intake, E303 cam, upgraded fuel rail and 30# injectors) I know the injectors are overkill but thats how I bought it. I can't get any traction. I can be cruising along and punch it and it just spins. From a stand still I hit my shift light at around 20 FT. Only one tire is spinning. Should this car have come with a Ford Trac-Loc Diff? If so I assume I need to replace the clutches. I appreciate any help.
I have 245/50/16 BF Goodrich Traction TA tires. I think my biggest problem is the one tire spinning. I need to replace my friction plates in the diff is indeed a limited slip? As far as the injectors go I have been offered a trade. Someone wants to trade me a different cold air intake (mine is a Pro M), a 65mm throttle body (mine is stock), 19# injectors and shorty headers for my injectors and cold air. I have an H pipe and flow masters but still have the stock headers. What do you guys think?
This is something the average gearhead can do. about 90 dollars for the clutch pack and no need for a need for a rear gear install procedure. Just yank the axles and the carrier and do the clutches. If he install the new carrier it will be like a gear swap. You will have to buy fluids in either case. It would all come down to the shape of the spider gears.
