Motor Install
Old Mar 5, 2009 | 09:52 PM
89musclestang's Avatar
89musclestang
Default Motor Install
my motor is ready to be put in my car now... but i already torqued the heads to the block and i wanted to lift it from block with 2 bolts on opposing sides.... so with the heads on the block would it mess up my head gasket to take 1 one bolt on each side out to set it in car and then retorque them?
Old Mar 5, 2009 | 10:07 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
use an intake plate
Old Mar 5, 2009 | 10:23 PM
89musclestang
don't got one =/... so would that hurt to do that?
Old Mar 5, 2009 | 10:26 PM
BlessedHellride's Avatar
BlessedHellride
It has been done millions of times, lift it from the ends of the heads, not one of the head bolts/studs. It will be fine.
Old Mar 5, 2009 | 10:27 PM
SonicBlueFiveSlow's Avatar
SonicBlueFiveSlow
Buy one or make one, you can make one with 2 pieces of angle iron welded back to back.
Old Mar 5, 2009 | 10:28 PM
mjr46's Avatar
mjr46
most likely no but there are better ways to do it, stock engine had lift eyelets bolted to headers, if you hae those still use them
Old Mar 5, 2009 | 10:32 PM
89musclestang
what would i attachh my chain to if i shouldn't use the head bolts?
Old Mar 5, 2009 | 10:34 PM
mjr46's Avatar
mjr46
go buy some bolts the size of the holes where the accessory bracket bolts to on the heads
Old Mar 5, 2009 | 10:37 PM
BlessedHellride
I put my engine in my turd this same procedure. Not proud of it, but didn't have correct intake bolts so I didn't want to take he chance of dropping the engine on the lift.
Old Mar 5, 2009 | 10:45 PM
89musclestang
go buy some bolts the size of the holes where the accessory brackest bolts to on the heads
yea but thats just for the front of the heads i want to pick it up from the front on one side and the back on the other
