Fabrication!
Old Mar 6, 2009 | 06:59 PM
calfroper_06's Avatar
calfroper_06
gotcha, i want to go that route instaed of filling all the holes in the radiator support. looks great, and the motor looks awesome too!!!
Old Mar 7, 2009 | 09:19 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Looks good, at least you did it right the first time and didn't screw up the bends!
Old Mar 7, 2009 | 02:17 PM
Shelty's Avatar
Shelty
looks great, not bad considering the exact same part from UPR costs like 50 bucks i think
Old Mar 7, 2009 | 04:01 PM
86HOGT's Avatar
86HOGT
That's what a little measuring gets you!
Here's some progress I made today.
That other cooler on the radiator will be for power steering.
The fan's motor is like an inch and a half from the water pump pulley!
Old Mar 7, 2009 | 10:42 PM
w8less's Avatar
w8less
Originally Posted by 86 5.0L
nice wall!
no kidding. keep on the good work though
Old Mar 10, 2009 | 02:48 PM
86HOGT's Avatar
86HOGT
Default Update
Here' s a little update on my big build...
I got the radiator mounted in for good after waiting for the right lower hose to get here. It was actually cheaper from Ford than the parts store. I was also waiting for -6 AN to 3/8" barb hose to get here so I could hook up the power steering cooler.
Lame stock cooling...
If you're wondering why I have five of those tie straps, it's because I had to move one for the cooler so the fan could sit flat on the radiator and the odd ball one is holding the bottom part of the fan as well.
Now, I'm just waiting for an overflow tank from Summit that will be here tomorrow, battery cables (since mine were pretty wore out), and then I can start wiring the fan up.
Old Mar 10, 2009 | 04:41 PM
symonds86's Avatar
symonds86
nice what radiator is that
Old Mar 11, 2009 | 07:58 AM
86HOGT's Avatar
86HOGT
It's a Northern brand radiator.
Old Mar 14, 2009 | 01:01 AM
86HOGT's Avatar
86HOGT
I got it all wrapped up today. The fan control I got from OK Auto was pretty cheap. They could have given me about a foot more wire for the temp probe because it's only reaching to the right half of the radiator and I have to set it real low to maintain engine temp. I'm either going to extend the wires or go with a completely different sensor. Not to mention I broke the stops for the tiny adjustment on it...meh...
I also had to make a a little bracket for the overflow tank.
Old Mar 14, 2009 | 05:22 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Nice job!! Looks great!
