351 block question
will a 351 block bolt right on using heads intake manifold oil pan etc. from a 302? i know the exhaust wont but i want to know if a 351 block will use heads and intakemifolds made for 302?
okay for my engine build if i choose to use a 351w and still use efi i found that trick flow makes intake manifolds but what about cams distributors all the other parts are they easy to find?
and does the 351w use same engine mounts as the 302? will it drop right in?
https://mustangforums.com/forum/351-...onversion.html
This should answer alot of the questions you have about a 351W swap. Alot of good information on this thread so definitely check it out.
Sep 8, 2015 05:21 PM
