E7 Porting
Old Mar 16, 2009 | 08:25 PM
shawnk007's Avatar
shawnk007
Default E7 Porting
Has anyone had any proven success doing a mild DIY port job on their E7s? And is there any change by removing the hump in the exhaust port for the smog equip.?
Old Mar 16, 2009 | 10:38 PM
89musclestang's Avatar
89musclestang
trust me man not to be a dick im just sayin if you want to put any money in those heads just ditch em and go to the junkyard and get gt40 heads the e7's arent worth it
Old Mar 16, 2009 | 11:03 PM
w8less's Avatar
w8less
look into thumper head porting
Old Mar 17, 2009 | 06:26 AM
BlessedHellride's Avatar
BlessedHellride
Yes, there is performance gains to be had from a good P/P job on stock heads.
Old Mar 17, 2009 | 08:25 AM
we b gpn's Avatar
we b gpn
here ya go
http://www.thumperoforangepark.com/
Old Mar 17, 2009 | 10:32 AM
w8less's Avatar
w8less
the big question is though is it worth the money?
Old Mar 17, 2009 | 10:42 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
mid-low 12's on 1090 from thumper or low 13's high 12's from AFR nah not worth the money.
Thumper Heads and Cam combo #1 : Thumper Ported E7s (219/155 cfm)
* Vassco springs, moley retainers and keepers
* For cams to .600 lift
* Double roller timing chain and gear set w/9 position key way
* FMS "E" ( for AOD cars), "B" , or TFS1 cam
* Instructions on installation and Cam phasing for the best power and performance for you application
* Proven 12 sec combination
* $1090.00 + 100.00 refundable core charge**
Old Mar 17, 2009 | 11:37 AM
Timspony's Avatar
Timspony
SVT Section Moderator
If can port them yourself and have the equipment, I'd go for it, otherwise like stated ^^^^, get some GT40 or better heads!
Old Mar 17, 2009 | 02:57 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
not worth it unless you are involved in class racing where you must use stock stuff in a class
Old Mar 17, 2009 | 03:04 PM
w8less's Avatar
w8less
speaking of stock stuff. anyone hear about tommy with jpc pass? 11.072 fastest factory stock pass in history
