thinking bout switchin to carb
i have the same setup as stated above but you can go cheap and get a mr gasket elect pump good to 7 psi for like 40 bucks. use your old fuel line and bolt in a regulator. i love carb setups and there was someone else that just posted a similar post and i had to put my .02 there too. carbs are cheaper and easier to get power from and easier to work on. i get better MPG with mine as well. i would stick with a 650 or so carb though...i didnt read your mods but i had a 302 with mild mods and 750 poured way too much gas even after i had it tuned for the car. i just couldnt get it to run right, it can be done...just not worth the trouble
would this be a good intake and what kind of carb should i get
http://cgi.ebay.com/ebaymotors/ws/eB...4194&viewitem=
summit use holley design carbs,and everything i have ever bought or used by summit was of good quality and design...if i didn't like it or something was wrong they told me to send it back,and was replaced with whatever i wanted.
