thinking bout switchin to carb
ok so i have been thinking bout it for a long time time i can not get my car to run right what all is needed and what would be some good parts to get and also is there any benefits over efi
i was thinkin bout gettin this carb and intake set up would this work good with the f cam
http://store.summitracing.com/partde...6&autoview=sku
That kit seems to be a bit much for a 302/306 mild engine. See if they offer the same kit with a 650cfm carb. It should work way better than the big ol 750. I think the kit will work great, just call them and ask if they offer it with a smaller cfm carburetor and you would be set.
best way is remove efi pump and put a piece of tubing in place of it for pick up, and I ran a holley blue with a regulator set to 5-6 psi and I RAN new 3/8's braided line all th way to the front, but I intended to race mine so I went with more expensive stuff, in your case the holley red pump using the existing feed line should be adequate with a few mods to it under the hood.
