thought I'd make a new video
#27
http://www.youtube.com/watch?v=zCUEiWywYkI
Like i said depends what vid you watch of mine
http://www.youtube.com/watch?v=dwzWBjAsZPg
#30
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Type: Camshafts
Part Number: CCA-35-351-8
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,800-5,800
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
Lobe Separation (degrees): 114
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer-Controlled Compatible: Yes
Grind Number: FW XE270HR-14
