A day at the track...... new best!!
Today was a local private track rental for a local Mustang club. So after much anticipation, a new set of 4.10's, (thanks Mike) and a tad bit taller tire I gave it my best. Last years one and only outing yielded a very disappointing 12.34@115.08 for my fastest run.
So my first 2 runs were kinda carbon copies of last years, 1.9 60's, and a pair of 12.4's. My trap speed was back up at 117.78 and 118.41 respectively. I was trying coming out a lil softer by slipping the clutch. Didn't seem to be working out like I hoped.
The third run, I went back to high rpm launch which got me a nice 1.630 60' and a 12.171@116.22. Finally heading back in the right direction
Forth run, dropped the hammer, 1.522 60' for an 11.798@117.36
Fifth run, 1.586 60' for an 11.761@116.81
Sixth and last run, 1.655 60' for a 12.277@102.56 I ran out of gas the last run. By the 1000' mark the car was sputtering like crazy.
Here's the vids!! I finally broke into the 11's!!!
http://smg.photobucket.com/albums/v3...Picture002.flv
http://smg.photobucket.com/albums/v3...Picture003.flv
http://smg.photobucket.com/albums/v3...Picture006.flv
http://smg.photobucket.com/albums/v3...Picture013.flv
http://smg.photobucket.com/albums/v3...Picture014.flv
http://smg.photobucket.com/albums/v3...Picture033.flv
Had some coaching form the sidelines to help me get on track. Thanks Mike!!! It's def easier when someone is watching that can tell you what's going on w/ your car from the outside about things you can't see from the inside.
1/8 mile was
1. 8.233 @89.81
2. 8.250 @88.78
3. 7.896 @88.02
4. 7.587 @89.80
5. 7.571 @90.84
6. 7.792 @88.90
OK,
List of mods.......stock block heads and cam. Stock T-5, Dyno #'s, 368/406
MGW shifter
BBK ceramic equal length shorties
Mac H pipe
SLP 1 cat back w/ 3.5" polished tips
4.10 Ford racing gears
31 spline Ford racing trac-lok w/ carbon fiber clutches
31 spline superior racing axles w/ 3" studs
5 lug conversion
Autometer gauges
Autometer Phantom Monster Tach/shiftlight
Lightning audio amp and 10" subs in custom sub box
Sony cd head unit
Cervini's cobra r hood
2003 front Pony seats
SCT custom burned multi tune chip
MSD 6al ignition system
MSD dist. cap
MSD Boost timing retard module
Crane fireball ps 91 coil
Ford Racing 9mm ignition wires
ATI Procharger 14lb boost w/ 3 core intercooler
Polished PA Proformance 3G 130 amp alternator
255lph Holley in tank fuel pump
Canton Racing aluminum overflow tank
Professional Products Typhoon polished intake, 70 mm throttle body and egr plate
2 core aluminum radiator
Ford Racing polished aluminum valve covers
Billet distributor hold down
Misc. chrome parts for underhood accessories
Battery relocate
Custom billet battery tray
Optima red top battery
BBK cold air intake
15x8 Prostars w/ 275/50/15 Hoosier drag radials
15x3.5 Prostars w/ 165/15 street radials
FMS 42# injectors
Pro M 75mm blow-thru mass air
Anderson Power Pipe
Kirban AFPR
Mac lower control arms
CHE double upper adjustable control arms
Sub frame connectors
UPR upper and lower torque box reinforcements
Hurst roll control
Lakewood 50/50 rear shocks
Lakewood 70/30 front struts
Centerforce DFX
AEM wideband
PA Racing tubular k-member, a-arms
Strange coil overs
MM caster camber plates
Oh, I did see a full 14lbs of boost crossing the traps at just over 6K. I finally have the right combo as I was just hitting the rev limiter as I was literally going through the traps!! 4.10's FTMFW!!
Thanks!
I knew your car had it in it, when we were standing there and saw you finally hammer it hard outta the hole and the rpm didn't drop and no noticible shift lags, I knew it had to be close to an 11 expecially when we saw plenty of day light under the front tires!!! Congrats!!! good job!!! ...My only regret is I didn't have my ride there to run also...oh well there's next time
