Clutch question
Clutch question
I am having a problem with my clutch.
When the car is off and parked, I can shift very easily. When the car is on, I have a bit of trouble putting it in gear. I can pop it in first, but it will turn off.
I do have trouble shifting too.
Do i just need to change out my clutch/flywheel?
When I put it in gear when I am shifting I can feel the wheel spinning but it seems like it is not stopping to let me put in in gear.
Any suggestions?
Thanks Guys....
Any suggestions?
Thanks Guys....
It is a 93.
I dont think it is going in when I push the clutch in. All I feel is the stick hitting the turning wheel. Then if I slam the clutch in and put it in 1st, it turns off. I think the clutch may need to be replaced because I slam my foot down all the way in, and it doesn't allow it in gear.
Okay guys, I called around to different shops and I was told (over the phone) that i need a new cable?
Some sort of cable that will help switch gears better. That is the reason I have trouble shifting and it is so tough to change gears and put in 1st.
Does anyone know about this or what cable this is?
I have never heard of it.
