PCV valve location?
Old Apr 16, 2009 | 07:46 PM
zippo2341's Avatar
zippo2341
Default PCV valve location?
ive had a few posts up here already but im basically trying to do as much preventative maitnence before i got to college as i can, and i havent done this yet. Where the h*** is the PCV valve on this car, 95 GT?, ? ALso is the screen easy to get to, and can i just clean it with engine degreaser, or is it better to just put a new one in? Anybodys 2 cents is appriciated, thanks Jay.
Old Apr 16, 2009 | 07:50 PM
mstngsule68's Avatar
mstngsule68
back of the intake manfiold, just buy a new one
Old Apr 16, 2009 | 08:26 PM
Explosive's Avatar
Explosive
Just buy a new one, They're cheap.
Old Apr 16, 2009 | 08:37 PM
zippo2341's Avatar
zippo2341
is there anything "special" i have to remove to get to it? Also where at specifically is the PCV i know the screens are generally underneath the PCV valve? I was checking behind the manifold today but with the night coming i couldn't exactly find it
Old Apr 16, 2009 | 10:52 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Ooh …I just know that I’m gonna get chastised for posting these pics but it’s the best I can do to help showing you the PVC location and screened filter, so with that being said.
PCV Location
Rubber Grommet that holds the PCV in place
Screen Location
Screen
You can remove the screen with either needle nose pliers or a screw screwed into the metal filter.
Old Apr 16, 2009 | 10:57 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
that is a good looking stang.
a screen isn't but like 5 bucks so just get a new one.
Old Apr 16, 2009 | 11:48 PM
jthorn9's Avatar
jthorn9
The Godfather
The PCV just pulls out, however you'll have to work a little to get the grommet out, and even a little harder to get the filter out, all of which should be replaced. Be prepaired to remove the upper intake if push comes to shove because you don't want the filter in the bottom to become clogged, that's just as bad as the PCV valve failing. Don't worry, removing the upper intake will take all of 20 minutes, and the same to put it back on.
Old Apr 17, 2009 | 09:19 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
tape a screw to the end of a long srewdriver to get it out
Old Apr 17, 2009 | 04:33 PM
OnyxCobra's Avatar
OnyxCobra
my PCV valve grommet literally fell right out when i took the lower intake off, was totally shot.
Old Apr 17, 2009 | 08:55 PM
zippo2341's Avatar
zippo2341
wow i dont think i could ask for any better of a detailed pic, thanks alot! does the grommet come out easily or is it something you have to pry at? I just dont wanna rip it! but im sure it would be cheap fix if it did rip
