Door trouble shooting
I was wondering if there is anyway to check the motors in the windows and door locks?
Would it be easier to just replace them?
The driver's side will lock the passenger side but not the front.
The passenger's side wil not lock either.
The driver's side will roll the driver window but not the passenger.
The passenger will not roll down with it's switch.
I have never opened everything up on the door and checked if things are connected. I just figured the motors were out.
Sounds like you have a bad master switch or a bad ground. Pull the armrest off and check for power and ground. If you have both then the switch is probably bad.
If a motor is bad just one thing will not work. Since you have multiple things not working check what is common between them, the master switch.
Sep 25, 2015 06:58 PM
