Adj Prop Valve
Adj Prop Valve
So, how will I know what to set my adjustable proportioning valve to? I just finished up the brake conversion, system is all bled, all that is left to do is adjust my toe(thanks to sn95 spindles), put on my catback, and some minor adjustments, like clutch and adjustable prop valve.
Thanks, that helps a good bit. At least I know where to start. But still, how will I know which wheels lock up first/how will I know which way to adjust it? Will I be able to feel the difference from inside the car? Will the car nose dive if the front brakes lock up first?
