Fuel pump location???
Old Apr 29, 2009 | 06:23 PM
Portmaster's Avatar
Portmaster
Default Fuel pump location???
I'm using a Granatelli pickup in tank, Holley HP125 electric pump. I need some suggestions about the pump location. I need the pump inlet and outlet at least as low as the bottom of the tank. I didn't want a sump in the rear of my car so I went this route. If You have pictures of you mounting location I'm wide open to sugestions.
Old Apr 29, 2009 | 08:06 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I put mine behind the rear bumper, but that may not be as low as you want it
Old Apr 30, 2009 | 12:08 AM
redpony88's Avatar
redpony88
i know it's no where near what you said you wanted but on my 83 i put it where the fuel filter goes on later cars
Old Apr 30, 2009 | 07:35 AM
Portmaster's Avatar
Portmaster
I need to mount it somewhere in front of the tank. I just need to keep the inlet/outlet about an inch lower than the bottom of the tank or at least level. I want the fuel pump to be able to have a siphon effect that way the pump doesn't have to suck the gas. I may just build a bracket to mount it right in front of the tank. I had even thought ablut mounting it on the rear subframe right but where the ebrake cables make the 90 degree turn just in front of the lower control arm. I'm use to having all kind of room and a full frame to work with. Very limited space to work with
Old Apr 30, 2009 | 04:48 PM
kweb288's Avatar
kweb288
would this work? its mounted in front of the tank before the rear, Its a special bracket (you could probably make it), ive seen it in multiple magazine cars also
Old Apr 30, 2009 | 05:10 PM
hi_tek_rednek's Avatar
hi_tek_rednek
i mounted mine on the side of the spare tire well. not sure if its lower than a stock tank line since my tank was gone and i put in a cell in the spare tire location.
Old Apr 30, 2009 | 06:08 PM
AdderMk2's Avatar
AdderMk2
Banned
I know someone who mounted theirs to the plastic tank shield with a piece of sheet metal on the inside of the plastic to keep from ripping the bolts through
Old May 1, 2009 | 06:00 AM
Portmaster's Avatar
Portmaster
I ended up mounting it very similar to this. I welded a peice of metal to the flat spot where the old fuel filter bolts up and then bolted it to that. I got it to withing an inch of the bottom of the tank (dont want to drag it off) so I'll be good. I had a time getting that -8an line to exit on top of the tank. I had to beat a small groove into the top of the tank so it wasnt crimped. It's in there no so just have to wire up the relay today and check for leaks. I need to get one more 90 degree fitting to make it just right but I should be able to fire it this afternoon.
jwog666
Dec 27, 2021 08:09 PM
b8checker
Oct 8, 2015 12:55 PM
svfetter
Oct 5, 2015 11:39 AM
b8checker
Sep 30, 2015 07:11 AM
mrappe
Sep 26, 2015 10:16 AM
